ORP Probe not working... I think
thekameleon
Post by thekameleon »
So I got my 470mv solution today and I tried to calibrate it. When I used the BNC terminator I got around a value around 1568, then I connected the probe and put it in the 470mv solution and it comes up 0. SO once calibrated it shows up as zero. Just to see if the probe works I put it in the tank it and check the calibration menu just see if it returned a value and I got 678. I am so confused. Please help
Re: ORP Probe not working... I think
Did you break in the probe?
thekameleon
A break-in period... No what do I have to do to break it in. I don't remember seeing that in the manual.
Yeah, leave it in the tank for a couple weeks.
thekameleon
Its been about 2 weeks now and still get the same results. In the tank I get a value of 168... the 50 ohm resistor bnc is about 1568 and in the 470 mv solution 0. Nothing has changed from a week ago. Is this normal?
Let's watch the chart for the next day or two to see the pattern.
It needs to go the reverse of pH readings.
jsclownfish
Post by jsclownfish »
I was wondering about my ORP as well. I don't know a lot about this sensor, but I'm guessing it shouldn't look like this....
I tried moving it to another part of the sump, but I still get these sharp drops that don't seem to correlate to anything.
Should I try another probe?
-Jon
thekameleon
If I were to take a guess. Is there a lot of air bubbles in your sump and could air be getting into the probe? I have my probes in a low churn area of my sump that has baffles to slow down and stabilize the water movement.
thekameleon
Grrr.... So the ORP probe just stopped working when I try calibrating it again. For 0mv with the terminal I get a value of 1568 and with the 470mv solution I get a value of zero. And in my tank I get a value of zero, however RO/DI water I get a value of 69. Are these expected values?
I think there is something else wrong with the module then.
It is not supposed to be that much of a gain.
PM for RMA.
