PWM and Steve's LED Help
ReeferSteve
Post by ReeferSteve »
Hey Guys,
So recently upgraded tank and thought I'd upgrade my code to go with it.
I got some Steve's LED double drivers which are supposedly RA compatible (although I'm beginning to doubt it) and I'm having some real trouble getting the LEDs to work using the PWM output.
I've tested that the PWM is giving voltage, I've made sure its not the cables and on the driver output to the LEDs I get a voltage reading. I read a voltage of 23.8 so PWM dimming or not the lights should switch on but they dont!
When using the pot and having set the drivers to 'manual', the lights work fine.
Any ideas? I'm mailing the guys from Steve's LEDs today.
Another issue I'm having is that no matter what my % dimming is, my moonlight always seems to show the same brightness; currently running it off my PWM expansion module.
On the board, I bridged the SDA, SCL as per the expansion module manual and the RST was already bridged.
The ICSP has no bridges.
Is that all correct?
I also used RA wizard to generate a basic set up for me while I made sure everything worked and is all below:
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.StandardFan( Port2 );
ReefAngel.DayLights( Port4 );
ReefAngel.DosingPumpRepeat1( Port5 );
ReefAngel.DosingPumpRepeat2( Port6 );
ReefAngel.ActinicLights( Port7 );
ReefAngel.DayLights( Port8 );
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMParabola();
ReefAngel.Portal( "ReeferSteve" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,76, ReefAngel.Params.PHExp );
Any problems with code generated? I haven't programmed with this for ages so not familiar with the syntax anymore.
I tried connecting the moonlight to different channels with different PWM readings but there was no difference in brightness (or noticeable difference in brightness) even though sometimes the PWM difference was >50%.
I'm using RA Plus Main Unit 2.0.
Steve
Re: PWM and Steve's LED Help
Using internal memory settings makes it hard to troubleshoot because we can't see the memory settings.
Are you getting voltages out of the dimming module? I'm assuming you got the PWM signal, right?
ReeferSteve
Ill rewrite with memory settings in code and upload later today!
I'm getting expected voltage from PWM from relay box but not with the expansion.
Getting a constant output of 10.59ish Volts no matter what the display says the PWM is at.
Thanks for the help!
Can you double check if you got the 2 jumpers (SCA/SCL) in the head unit?
ReeferSteve
Yip, attached below is a picture of the board.
Got the jumpers on.
Picture of board
Picture of board
Ok, can you follow the steps here and paste the results?
http://forum.reefangel.com/viewtopic.php?p=14763#p14763
IrvingFerguson
Post by IrvingFerguson »
ReeferSteve wrote:Hey Guys,
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// pH Expansion
Steve
Thanks for sharing the code.. I have been searching for it for a while and finally got it.. Thanks again
