A little help
topjimmy
A little help
Post by topjimmy »
I am not sure what happened but it was in short term a disaster. I updated my RA last night with this code
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.DelayedOn( Port2 );
    ReefAngel.StandardHeater( Port4 );
    ReefAngel.DayLights( Port7 );
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=5;
int maxOffset=10;
int min=speed-minOffset;
int max=speed+maxOffset;
switch (mode) {
    case Lagoon:
        //lagoon
         ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
       // ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
        break;
    case ReefCrest:
     //reefcrest
       ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
        //  ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
       break;
    case NutrientTransport:
     //nutrient transport
     ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
      //  ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
     break;
    ReefAngel.Portal( "topjimmy" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
For some reason the ATO power never turned off, what is worse is that it put, over night, almost 10 gallons of freshly made Kalk into the system. My Ph is almost at 10 accorCding to the RA, I am probably looking at a complete loss, but time will tell I guess.
Is there anything in that sketch that would keep that port on?
A little help
What port is your ato pump on? All i see are On ports...
topjimmy
Re: A little help
Post by topjimmy »
port 3, heater on port 4
I had put a delay on it just to be safe during water changes and such....possibly a bad idea....
Re: A little help
Yeah. That port is coded to be on all the time and not as ATO.
You need to change this:
Assuming you are using the ATO Low port, to this:
ReefAngel.SingleATO(true,Port3,60,0);
topjimmy
Re: A little help
Post by topjimmy »
I did it late last night and was stupid enough not to make sure it was working correctly.
Thanks for the help . I'll make the change and hope for the best.
A little help
Yeah, you basically declared it as an always on port...no setting for ato functionality. :(
topjimmy
Re: A little help
Post by topjimmy »
I should know better than to do something like that and not test functionality. What It did was delayed the start for the 60 seconds after the upload, so it appeared as if it was off and functioning as ATO, then I left and the gd thing turned on , just like it should have. :? DOH!
Re: A little help
Yeah, that's exactly what happened :(
Re: A little help
Since you are pumping Kalk, my recommendation is to kill that port if pH rises to a certain level...
Like this:
if (ReefAngel.Params.PH>850) ReefAngel.Relay.Off(Port3);
A little help
rimai wrote:Since you are pumping Kalk, my recommendation is to kill that port if pH rises to a certain level...
Like this:
+1
topjimmy
Re: A little help
Post by topjimmy »
Good idea.
I need to set up the peristaltic pump I have for dosing the Kalc on that port. At least it would not have been able to dump 10 gallons in over night.
topjimmy
Re: A little help
Post by topjimmy »
OK So I set up my dosing pump to be my ATO pump.
So let me run this by you, dosing pump comes on every 60m for 20s
If ATO low is on ( i assume that means water level is low) then it lets the timer go on.
If the ATO high is on ( I assume this means water level is too high) then turn off the port,or don't turn it on at all.
If the ph is at or goes over 8.5 during the time on turn off the port.
How would I code that?
I have a basic idea but I want to be sure.
Re: A little help
It was already posted earlier in this thread:
http://forum.reefangel.com/viewtopic.php?p=24659#p24659
topjimmy
Re: A little help
Post by topjimmy »
rimai wrote:It was already posted earlier in this thread:
Well kind of, I don't want the ato to trigger the event, just allow it to happen or not, at the same interval.
Re: A little help
Ahh.. Sorry... I misread the post.
    ReefAngel.DosingPumpRepeat(Port3,0,60,20);
  if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port3);
This will do the following, assuming both floats are pointing down:
ATO Low is down, let the timer run.
ATO Low is up, turn port off
ATO High is down, does nothing
ATO High is up, turn port off
Is that what you wanted?
topjimmy
Re: A little help
Post by topjimmy »
I think that is perfect. thanks again.
topjimmy
Re: A little help
Post by topjimmy »
just a quick question,
Both the ato floats are oriented in the same direction, cable up. On the portal, what is the significance of the ato color being red or green?
If ATO low (the float lowest in the sump) is green that means that the float is high, and the pump will not turn on,
The ATO high is red, and should never go green unless there is more water in the sump than should be.
right?
Re: A little help
The green means the float piece is not floating.
topjimmy
Re: A little help
Post by topjimmy »
ok i'm good then ato low is red ,ato high is green just as it should be
