water level expansion pipe
Drs1210
Post by Drs1210 »
What are those orange things called that are on the top of the water level expansion pipe where the 1/4 inch tube goes? Also where can I buy some? This may have been asked before but, can I change the length of the pipe and the 1/4" tube?
Re: water level expansion pipe
I'm not sure what those are or where you can buy them. the length of the pipe and tubing can be any length you need it to be.
You just need a sealed pipe... if you get a pvc pipe that fits into the cap that came with yours you can extend to whatever you want. If you need to replace it completely, you can just drill a hole and seal it with silicone maybe... as long as it's airtight. Maybe roberto can chime in :)
It's an adapter for gardening tubing. 1/2" PVC to 1/4" tubing adapter.
Drs1210
Post by Drs1210 »
Great, thanks for the help.
Drs1210
Post by Drs1210 »
Would there be an issue if I made the pipe around 22" long?
Drs1210
Post by Drs1210 »
Bump
No. you will be fine :)
Drs1210
Post by Drs1210 »
Great! Now just waiting on the multi water level expansion :D
rimai wrote:It's an adapter for gardening tubing. 1/2" PVC to 1/4" tubing adapter.
What store did you get this at and can you get a 3/4" to 1/4" tubing adapter?
i have a lot of 3/4" pvc and would like to use it instead of buying 1/2" pvc. if you can't get a 3/4" adapter, then I will probably convert the 1/2" to 3/4" pvc.
Sent from my Nexus 7
For 3/4", you can use a cap and drill a hole in it.
I did this and it worked fine for me :)
rimai wrote:For 3/4", you can use a cap and drill a hole in it.
awesome. that sounds like a plan. :)
Sent from my Galaxy Nexus
Drs1210
Post by Drs1210 »
I found the 1/2" ones on amazon. They are made by lasco and 5 cost aound 5$
Drs1210 wrote:I found the 1/2" ones on amazon. They are made by lasco and 5 cost aound 5$
A place called Star Nursery has 100 of them for $19.99.
You could also use a 1/2" to 3/4" adapter.
Drs1210
Post by Drs1210 »
Ya, I found it there too, but I couldn't justify buying that many when I only needed one. Also, I get free shipping through Amazon.
No problem, just pointing them out.
I was going to use this adapter but wasn't for certain if there was anything "easier". I think I'm going to try the cap on the 3/4" tube and see how that works for me. I'm only going to use it to monitor the reservoir level.
