My 125 Gallon Reef and I need some insight on my RA
Frogman
Post by Frogman »
Hello all!
I wanted to share a little about my tank and then request a few different pieces of help. I am new to the RA community and to the RA controller itself. I considered myself a bit of a geek and then realized, I am not as smart as I had hoped on certain things :-)
I just ordered my Wifi addon and should be getting that up and running in a few days.
I primarily have two questions to start.
1. Does anyone on here have a method to make the SB Reef Light 32 controllable? It only has 10 programmable slots and does not allow for a very smooth transition. Not sure if anyone has found or developed a hack for these lights yet. Mike, the guy who runs SB, has a hack for the regular Chinese Black Box, but they are not the WIFI controlled variety and I do not want to risk jacking that up. Haven't heard back on my request from him...
2. Being new to this community and this controller.. What are some items you would really "need"? Here is what I have on my current system.
RA Plus with only 1 power module and Wifi on its way:
Jaebo (2) WP 40 wavemaker (Uses the 2 powerhead controller)
Sicce return pump (700-900 GPH)
Chiller fed by a Aqualite Canister Filter (with mechanical filtration)
(2) 32 inch SB Reef Light WIFI controlled LED
(1) Stunner actinic use above my frag rack) ONLY on with daylights
4 Canopy cooling fans (Used to run MH Fixture, so there may not be a need for them now)
Coralife 220 Skimmer
Hydor ATO (5 gallon with aqualifter pump) (should I keep or control with RA?)
250 Watt Heater
30 gallon sump
What I am looking to do is maintain a simple system, I don't have tons of experience in programming, but I am learning. I would like insight and suggestions on where to go from here... What modules are imperative, (Natural Moon light cycle is one I plan on getting soon unless there is another method.)
I know not all the information you need is here, but again, not really certain what to ask.
Thanks in advance and I will post more details as I get in my Wifi controller and get my portal setup.
Blastomusa
Blastomusa
Nice Bubble Ricordea
My Tank 125 Gallon LPS/SPS Dominated Tank
Frogman
Re: My 125 Gallon Reef and I need some insight on my RA
Post by Frogman »
Ok, So I cant figure out how to get these pictures to show only in thumbnail mode... But its ok.
Here is my code, I am going to be working on my ATO tonight and getting that setup. My Wifi piece should come in this week and I will get that setup as well. I am also getting another temp controller to put into my canopy to activate my canopy fans if the temp gets too high (shouldn't, but failsafe on temp).
Please offer any suggestions, solutions, ideas!!! I'm still a serious NEWBIE in this realm.
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port1,5,0,10,0 );
ReefAngel.StandardLights( Port1,19,00,22,45 ) ;
ReefAngel.StandardLights( Port2,5,45,10,0 );
ReefAngel.StandardLights( Port2,19,00,22,00 ) ;
ReefAngel.StandardLights( Port3,9,55,20,30 );
ReefAngel.StandardLights( Port4,12,0,20,0 );
ReefAngel.StandardHeater( Port7,760,780 );
What else are you looking to add?
Frogman
Post by Frogman »
I will probably need to add another Relay box (I need to send in my current one because port 1 has a short in it, and I am not sure I wanna be opening it up and messing with it (unplugged or not)). I still want to figure out how to set/add a programmable option to the lights (SB Reef Lights) but talked with Mike and that is a work in progress (it would be cool if RA could pair up with him and develop a control mechanism for those!). I also want to add a couple reactors (Kalk stirrer (comes in today!), Dosing pumps perhaps, maybe Jaebo control..?) Not sure.
My tank is only a year old and I have a lot I can add, but not sure what would be best. My tank is doing well, but I just want to add a few more failsafes and a little automation to ensure that my tank stays a little more stable. (PH especially as mine swings from 8.3 in the day to 7.95 at night) I love the chart option too, that been a very handy item for me!
I also need to read up on wifi a little more as I can see my items on the portal, but I cant adjust them. Not sure how to do this yet, but I need to do a little more reading. I can access it fine from home, but when I am at work or a friends house I get the message that I am "unable to process controller data" even though I am connected via a wifi. So I know I have missed something, but what? Also, online, I cant connect from work as I get an error message as well. Not sure if I am missing multiple steps or just a key one.
Again, I need to read more.
I do like the lighting control you helped me with! so once again, thank you for that.
