I just received my Reef Angel yesterday. I setup the controller through the wizard, and had no issue with the wifi or port forwarding.
My only concern is that when I uploaded the settings uses with the controller, I now have 16 ports, but in actuality I only have the one powerbar. I did ensured I did not select the expansion box on the wizard setup. I have even reset to the preloaded code and then went through the wizard again, still the same results.
Below I have attached the code I currently have loaded.
I would really appreciate any help!
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
// Define labels for 2014 LCD screen
ReefAngel.CustomLabels[0]="Metal Halide";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Return";
ReefAngel.CustomLabels[4]="BP Reactor";
ReefAngel.CustomLabels[5]="JBJ ATO";
ReefAngel.CustomLabels[6]="Wavemaker";
ReefAngel.CustomLabels[7]="Moon Light";
ReefAngel.MHLights( Port1,15,0,0,0,10 );
ReefAngel.StandardHeater( Port2,777,785 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.Portal( "SlimyEel" );
