*New User*-Why do I have 16 ports on controller
SlimyEel
Post by SlimyEel »
Hello,
I just received my Reef Angel yesterday. I setup the controller through the wizard, and had no issue with the wifi or port forwarding.
My only concern is that when I uploaded the settings uses with the controller, I now have 16 ports, but in actuality I only have the one powerbar. I did ensured I did not select the expansion box on the wizard setup. I have even reset to the preloaded code and then went through the wizard again, still the same results.
Below I have attached the code I currently have loaded.
I would really appreciate any help! :D
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    // Define labels for 2014 LCD screen
  ReefAngel.CustomLabels[0]="Metal Halide";
  ReefAngel.CustomLabels[1]="Heater";
  ReefAngel.CustomLabels[2]="Skimmer";
  ReefAngel.CustomLabels[3]="Return";
  ReefAngel.CustomLabels[4]="BP Reactor";
  ReefAngel.CustomLabels[5]="JBJ ATO";
  ReefAngel.CustomLabels[6]="Wavemaker";
  ReefAngel.CustomLabels[7]="Moon Light";
    ReefAngel.MHLights( Port1,15,0,0,0,10 );
    ReefAngel.StandardHeater( Port2,777,785 );
    ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port1 ) );
    ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
    ReefAngel.Portal( "SlimyEel" );
Re: *New User*-Why do I have 16 ports on controller
Where are you seeing 16 ports?
SlimyEel
Post by SlimyEel »
I see them on the controller lcd screen
screen 1
screen 1
photo 2.JPG (97.21 KiB) Viewed 3875 times
when I toggle over I then see this, and says port 17 on
photo 1.JPG (118.98 KiB) Viewed 3875 times
SlimyEel
Post by SlimyEel »
my apologies, 18 ports
Because you've defined a relay on the second box :)
As soon as it sees BoxX it will add that relay bar.
SlimyEel
Post by SlimyEel »
Thank you, weird just used that section from the wizard.
Thanks a lot! Love it so far
